Project data & BIM
AC crashed but didn't start from backup
heathldesign
AC crashed and went through the usual bug report etc. then it asked if i wanted to reopen which i clicked, but nothing happened. so now, where do i find the backup file? i had progressed quite far when it crashed and my last save was not as recent as i would like. the bpn isn't as recent as the pln.
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
Ideally you should shut all running Archicads.
Start a new instance and the autosave file should be in the start up list.
Open that and Archicad should open the file - unless it is corrupted for some reason.
If that does not work then you can try to open the autosave file yourself, but guarantee it will work
I am not familiar with Macs, but on a Windows machine the auto save files are in the user folder ... C:\Users\username\Graphisoft
There you should see "autosave" folders.
In there you should see other folders.
You may have to hunt around a bit for a file called "database.fdb".
It should have a current date and be a fairly large file size.
Copy this somewhere else and rename it to ... yourfilename.PLN
Now try opening that file.
No guarantee it will work - that is why you copy the file.
thanks Barry,
once i quit all instances it did show up at startup. once again, you da man.
