2004-10-01
10:43 PM
- last edited
a week ago
Molinda Prey
2004-10-16 05:25 AM
2004-11-12 01:47 AM
2004-11-12 02:01 AM
2004-11-23 01:11 AM
2004-11-23 01:15 AM
2004-11-23 01:35 AM
Ted wrote:I only received v9 yesterday so never had a chance to try it with 10.3.5
Boy, we've been solid on 10.3.5 for about three days now. Did you try 10.3.5 before 10.3.6...?
2004-11-23 03:01 AM
Aussie wrote:john, are you talking about actually setting up the shortcuts in your WE profile? if so, graphisoft have respected more of the OSX keyboard shortcuts this time around. if a shortcut 'belongs' to the system, archiCAD won't let you use it.
Trying to enter some keyboard shortcuts is not possible for instance opt-cntl-i cant be input.
A workaround is to put just opt-i into the field first (takes two goes) then opt-contrl-i can be input!!
2004-11-23 03:12 AM
~/archiben wrote:Ben as far as I can see opt/command/i isnt a finder keyboard shortcut
2004-11-23 03:17 AM
Aussie wrote:opt/command/i is 'get
Ben as far as I can see opt/command/i isnt a finder keyboard shortcut. Nor is opt/command/control/i- neither of these input into the WE
2004-11-23 04:24 AM
~/archiben wrote:damn you are right
opt/command/i is 'getmultipleinfo' ~/archiben
