‎2010-02-09
11:46 AM
‎2023-05-26
03:23 PM
Rubia Torres
‎2010-03-05 01:47 PM
creative wrote:YES !
Is it possible to add plaster by modifying the wall and columns as a complex profile and changing the skin priorities of the plaster in complex profile window?
will i get a correct floor plan display?
‎2010-03-05 02:23 PM
NeckoFromSarajevo wrote:I tried creating complex walls and columns(see fig)creative wrote:YES !
you can select anywall on you plan...capture his profile...add plaster...apply to selection and it will be well presented in plan...section...3d...
‎2010-03-05 02:31 PM
creative wrote:these lines will show up everytime when:NeckoFromSarajevo wrote:I tried creating complex walls and columns(see fig)creative wrote:YES !
it shows a line between plaster for wall and column.Prority for wall plaster skin is adjusted higher than the priority for plaster skin of column.
‎2010-03-06 06:01 PM
‎2010-03-10 12:04 PM
‎2010-03-10 12:56 PM
creative wrote:Wrapping Method: Not available for Profile (Complex) Columns.
How to plaster the remaning portion of the column? (see fig)
I read "Wrapped Columns on the Floor Plan" in help file but somehow couldn't get it.
Also how to plaster window|door jambs?
‎2010-03-10 01:15 PM
‎2010-03-10 03:19 PM
NeckoFromSarajevo wrote:I tried to change the column gometry to wrapped but nothing changed.creative wrote:Wrapping Method: Not available for Profile (Complex) Columns.
When placing a Column that will intersect a Composite wall, your choice of Geometry method - wrapped or unwrapped - will affect the display of the wall/column in the Floor Plan.
Use the wrapped/unwrapped (or “freestanding”) icons from the Column Info Box or the Column Settings dialog box to determine how the columns will be interact with composite walls.
Wrapped Columns can only break through the core skins of composite Walls. The other wall skins wrap around the column, retaining their thickness.
look at pic
‎2010-03-10 09:06 PM
