2009-02-17 07:28 PM
2009-02-18 06:09 PM
monkeybrain wrote:I understand your dilemma. On one hand you have a known system (2D CAD) which, however flawed, provides a known path to a completed project. On the other is BIM which offers great advantages in the long run if you can get over the trials and tribulations of implementation in time to successfully complete the project.
I want to make an informed decision on a strategic level. At the end of the day I will be responsible if the drawings are issued late and not the paid consultant.
2009-02-18 06:29 PM
monkeybrain wrote:No the fora are neither equal nor better nor worse than hired consultants. Only different. It is very useful in these decisions to get a variety of viewpoints, but I think the point is well taken that an online forum cannot provide advice that is specifically tuned to your needs.
I also find that most forums are an equal or better resource than a single expert.
2009-02-18 10:58 PM
monkeybrain wrote:I managed to customize translations both ways between Archicad and Microstation AND Autocad using Microstation's DWG conversion tools already in 1995. YOu shouldn't need a plugin, just thorough knowledge of the various settings files and options in Microstation.
As we had problems meeting the clients requirements in regard to linetypes and layers converting the files from Microstation I am positive that it will be impossible to achieve it in Archicad. Unless I get some wizard to write a custom plug in for me.
2009-02-19 11:16 AM
2009-02-19 12:39 PM
2009-02-19 01:38 PM
2009-02-19 05:44 PM
monkeybrain wrote:it sounds like this is the only real issue you
I know what you are saying but the client has the strictest requirements.
monkeybrain wrote:Well really what your company decides they will use get the job done is none of the clients business, so long as you deliver the product in the format they require, i.e compliant DWGs. So as others have suggested you could do most of the work in ArchiCAD and have a few guys on AutoCAD as kind of a 'clearing house' for your drawing output. I would assume you could do a similar thing with Microstation which you already use (i have not used in so long i cannot remember).
.. therefore the client insisted that all package drawings are to be done in Autocad.
monkeybrain wrote:Well i don't think he knows what he is talking about. There are plenty of projects towards that size that have been done in ArchiCAD. How you structure the model will be critical but it is the same in any CAD program (Microstation sounds like it has a bit of an advantage here though)
Archicad is apparently off the table as a 3D resource because the consultant thinks it could not cope with the size of the project. (500 meters long, 37 meters wide and about 6 stories high..)
monkeybrain wrote:Well although they seem to be doing their best to lose market share and stay niche they are nowhere near 1% ... yet.
The senior staff think it is a great opportunity to look at new possibilities but the consultant argued that Graphisoft only have 1% market share and are too niche.
monkeybrain wrote:Sounds like AutoCAD is what he knows so understandable that is what he is going to push. I wouldn't go out and tell a client they should be using Microstation. As Ignacio suggested I would strongly recommend getting some further opinions from people experienced in the other options you have ..
The consultant is proposing that we use Autocad 2009 for 2D and 3D.
monkeybrain wrote:Well if it is less efficient then it is not really the best option then is it? If it is possible to do the work in less time using a program other than the mandated AutoCAD and still deliver to the clients requirements then that is the option to go with.
...It sounds ok but is still nowhere as efficient as using BIM.
2009-02-19 06:04 PM
2009-02-20 12:10 AM
monkeybrain wrote:There is a UK survey that came out not long ago that tells about the numbers of various softwares in the UK. ArchiCAD is doing very well in it. YOu might want to show it to the senior staff:
The senior staff think it is a great opportunity to look at new possibilities but the consultant argued that Graphisoft only have 1% market share and are too niche. He also said that Archicad was made to create single dwellings and not huge infrastructure projects. True? (By the way he advices all the big London firms)
2009-02-20 10:58 AM
