2007-01-18 09:16 PM
2007-01-22 04:40 PM
Rakela wrote:Perhaps you should explain how it would actually work.Why not use Hotlinks? Everyone can do their part on the project and everything can be shown on a master file. At the end you just break the hotlinks and you have the whole project on one file...Tom, can you explain please whats wrong with the above ?
and thx in advance
2007-01-22 04:47 PM
2007-01-22 05:08 PM
Rakela wrote:Not at all. I was curious how hotlinks would actually work in that situation, since I don't see any way that they would successfully achieve what Teamwork can. I see a lot of potential short-comings, so many that I could not imagine even trying it. I thought maybe you had a way that worked.
i didnt mean to bother you in the 1st place, sorry if thecase !!
but your experience is formidable, and it would be really easy for you to explain why tmwk should be used and not hotlinking...sorry again
2007-01-22 05:30 PM
2007-01-22 07:25 PM
EVAN wrote:Actually you can do any of the functions assigned to a Team Leader except those that require exclusive access. Those would modify a portion of the work that is currently being shared; like changing a composite wall type, line type, adding stories etc.
Wow, you're responding early...thanks. Anywway...this sounds great, but are you able to update more than just layer combinations in the PLC?
2007-01-23 01:41 PM
2007-01-26 07:30 AM
2007-01-26 02:43 PM
2007-01-29 05:03 AM
