Project data & BIM
Archicad 25 5005 Layer missing in Module
fuzzytnth3
Just come across a strange thing. See screenshots attached. This is a Module file which contains only 2d lines nothing else.
For some reason when I access the Layer settings the only layer listed is "Archicad Layer" no other layers yet when I select any of my lines drawn in the module it shows that the line is on the  "B-00-M-Context" layer.
I have tried exporting the drawn content as a new Module but it is still doing it.
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
Minh Nguyen
Thank you very much for the report and I am very sorry about the issue!
I tried to recreate the issue on an empty file, but I was unable to replicate it. I'm wondering if there is anything special with the plan file used for creating the module? Or, could you reproduce the issue from a brand new file? If yes, I'm very interested in the process!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
fuzzytnth3
Hi Minh
I'm sorry for the delay. I haven't been able to recreate the issue. I have upgraded Archicad 25 to Build 5005 so maybe that has addressed whatever caused the issue.
Thanks for your time.
