ā2024-11-06 11:51 PM - last edited on ā2024-11-07 12:26 AM by Karl Ottenstein
Hello!
I've been having the same issue ever since starting to learn archicad, and the same problem appears with each document. Whenever I try to open the Surfaces menu from Element Attributes, the menu opens for a few seconds and then the app crashes. It only happens when trying to open this menu.
What could be the problem and how could I fix this?
Thank you
ā2024-11-07 12:24 AM
Your signatures says Windows 11. But, what version and build number of Archicad - Help > About... ?
What license type - professional, EDU, etc? Solo project or Teamwork?
ā2024-11-07 01:10 AM
I am using archicad 26, build 3001 INT EDU and only used solo projects
ā2024-11-07 03:14 AM
Do a check for updates. Build 3001 is the initial release and will have bugs⦠many updates since then with bug fixes. Latest build is 7004.
