Project data & BIM
Archicad crashing when opening "Surfaces"
fariafarfuria
Hello!
I've been having the same issue ever since starting to learn archicad, and the same problem appears with each document. Whenever I try to open the Surfaces menu from Element Attributes, the menu opens for a few seconds and then the app crashes. It only happens when trying to open this menu.
What could be the problem and how could I fix this?
Thank you
Your signatures says Windows 11.  But, what version and build number of Archicad - Help > About... ?
What license type - professional, EDU, etc?  Solo project or Teamwork?
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
I am using archicad 26, build 3001 INT EDU and only used solo projects
Do a check for updates.   Build 3001 is the initial release and will have bugs… many updates since then with bug fixes.  Latest build is 7004.
https://graphisoft.com/us/resources-and-support/downloads?section=update&localization=INT&type=FULL&...
Setup info provided by author
