a month ago
a month ago
There are better and worse ways of adding dwg's. At least you are not adding them as xref.
Maybe try saving out as pmk and add that back in instead of dwg? There is also a way of importing dwg content as object.
File - Interoperability - Merge - Merge from file - Select file and open - Model space into current view - tick the Import model space content as GDL object.
If none of that works, I would turn to Python script to see if there is a way to simplify or decimate - not sure how accurate you need the dwg to be but if it contains millions of very small lines, maybe you can get away with not showing them - python script could remove anything below certain size.
a month ago
Unfortunately you apparently cannot use Python to Overkill without first opening aCAD... Sadness...
