Project data & BIM
Automatic numbering in schedules
HelenE
Hello!
I have a question I wanted to ask all of you regarding automatic numbering in schedules. I have created a door schedule based on the type of door it is (ie wooden interior door). Let's say that I have 20 such doors in that project. I would like the first column to have the numbers in ascending order, listing these doors. Right now I'm forced to manually enter this information in each cell which is tedious when there are a lot of windows or doors. Is this automatic numbering possible? I've tried to indicate what I mean in the attached image.
12 REPLIES 12
brainclosely
Beginner
Thank you for your response. I figured it out.
coreball
LoisCook
Assign a shared parameter to doors if one is not already in use.
getaway shootout
Ricardo Lopez
Hi @HelenE
There is also an option to automatically create an ID based on criteria. Maybe that could work for you as well. Check the link below:
>>> ID Manager <<<
Regards.
M. Arch. Ricardo López
