‎2019-06-09 02:13 PM
‎2019-06-09 03:59 PM
‎2019-06-10 02:45 AM
Christophe wrote:I am sorry but this is an English language forum.
In France je n'ai encore jamais rencontré de solution "BIM global" sui soit pertinente dans la pratique
Je travaille personnellement au développement d'une solution qui soit aussi pertinente que facile à utiliser
Je vais néanmoins suivre ce post avec attention
In France I have never encountered a "global BIM" solution that is relevant in practiceBarry.
I work personally to develop a solution that is as relevant as it is easy to use
I will nevertheless follow this post carefully
‎2019-06-10 03:10 PM
‎2019-06-10 08:33 PM
Barry wrote:It was absolutely not voluntary. Thank you Barry for this little correction
