We value your input!
Project data & BIM
Basic Selection INFO PALETTE question
This question is so basic, but it has me at a stand still for work today - I lost the palette that gives you the information on your currently selected element. Example: if you select a polyline, usually there's a palette above that shows you the layer, the orientation to create, the color selected, etc.
But the palette has disappeared, and I've turned on all the toolbars and palettes, and it didn't show up. Is it off my screen somehow? I've restarted ArchiCAD, did not help. Please let me know!
ps. I'm on ArchiCAD SE
1 REPLY 1
insideru
Just reload the default Work Environment.
Go to Options - Work Environment - Apply Profile - Standard Profile.
(Note that this will also change your custom shortcuts. If you want to change just the UI go to Options - Work Environment - Work Environment. Select Workspace schemes in the list to the left (towards the bottom) then select Standard Workspace then hit Apply Scheme)
ARCHICAD 27 INT
macOS Sonoma
