Thanks to you all guys.
Let tell you what we are doing after all.
The project itself is a Terminal building for a new international airport. so its about 130.000. m2.
The basic solution we adapted was, split the main plp file into 6 new plp files:
1.
Interiors (walls, ceilings, furniture, storefronts, etc...)
2.
Structure (for Concrete and steel structure coordination)
3.
Envelope ( for the all the exterior walls, claddings, glazing work, Roof, etc..)
4.
Services Coordination (HVAC, fire, electrical, wet services, security, baggage handling, coordination)
5.
Procurement (for all the documentation regarding specs, quantities, etc...)
6.
Site ( for the terrain, roads, and the general exterior works.)
Of course all the Layout books are in different files, with the drawings linked to the specific plp where the view was saved. (... we have just missing those old pmk files.... quick access to a view trough a stand alone file)
The plp can see the others plp information with the hotlink, and not everyone need to see the services or the site, so we basically linked the structure, interiors and envelope.
The graphical Standards have been coordinated manually almost every friday. Is not that difficult after all.
Everything is working good, but still id like to warn you about some thinks that doesn't work 100%:
1. Grid Lines:
Sometimes you have 6 or 7 grid lines on the sections, some times you don't have any.
BUT we have discovered that if you want to see grid lines on your section viewpoint, and the grid lines are not in your workspace or in a hotlink, you have to set the Status of the section to Auto rebuild, it doesn't matter if you rebuild it manually, it doesn't work. Only auto rebuild works... and is not 100 % sure.
2. Layout books:
Updating Views from different PLP files that are 60mb (+) size its tricky sometimes. for floor plans details and worksheets works almost at 90%, but for general sections, you can wait for 1 hour to rebuild it and maybe an hour or 1 day to get it into the layout book. It is still a problem. That's why i would like to use PMK files again. This gives you the chance of recovering old versions of the project even in 2D.
3. Xref Layers:
To be honest, working with so many consultants and contractors... coordinating structure services, details, etc... you can't always be sure that some one will forget to remove those layers..... Once those layers are in your plp you are lost. you can not erase them. Right now we can count around 450 Xref layers and 220 Project related layers. What a mess.
Just to finalise this, I love this software, even that Revit 2009 has a very nice Rendering engine, Even that Is not popular as Autocad. But we need more Reliability....
R E L I A B I L I T Y.....
Thanks.... Thanks to you all.
Nando Mogollon
Director @ BuilDigital
[email protected]Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
