Project data & BIM
Bimserver not accessable.
justdhruv
My bim server is not accessible. Any ideas?
I have reinstalled it couple of times. I am running another bimserver for AC21, just fine
ArchiCAD 20. MacBook Pro 17", 2010
+ core i7 4970k Hackintosh
2 REPLIES 2
Hello justdhruv,
BimCloud software is on your computer ?
BimCloud software is on another computer ?
BimCloud is into your office or far far away ?
Are your collaborators far far away ?
If you try to do remote work for a collaborators.
Your modem is like a security guard who protects your client's home network.
To access a computer station (BimCloud server for example) you have to know :
- your client's modem public IP (and not its local IP)
- your client's BimCloud port (80 like example below)
- change client's modem port parameter to allow access
You may be at the computer at the bottom right
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
"Quality is never an accident ; it's always the result of an intelligent effort" John Ruskin
Noemi Balogh
Did you configure an external location for your snapshots?
If your answer is yes, then the issue is that you turned on a BIMcloud only feature in BIMcloud Basic, which blocks your BIMcloud Server to run.
Please check out: https://helpcenter.graphisoft.com/knowledgebase/87062/
Kind regards,
Noémi Balogh
Community Expert, Admin
