Jeff Galbraith
CLEARING ISSUE & CHANGE HISTORY?
Is it possible to clear the issue history on a file? We are creating our first office template and want to base it on the archicad file of our first Project, which contains everything we have developed so far. Unfortunately that file already has a few changes / revisions in it. ie: 4 issues have been closed in the change manager.
How do you clear the change & issue history from a file?
Jeff
Archicad 22
Mac OS-X 10.13.6
Jeff G
Archicad 27 USA (full), Macbook Pro (16-inch 2023, M3 MAX, 128 GB RAM)
1 Reply 1
From memory, you can "unclose" only the last issue. So delete that, then the previous issue will be the last, which you can "unclose", delete, and so on.
Then you can select and delete all you Changes in the Change Manager in a single step.
