ericatomasoni
Calculation Units & Rules limited to 0 zero decimals
Hi there.
I am working with Archicad 24 and out of nowhere, the units of some kind of dimensions (level, area, some values of lists, etc) were down to 0 decimals, showing only the number before commas.
Then I checked on Project Preferences > Calculation Units & Rules and find out that now my units are limited to 0 decimals!! Does anyone have a clue on how to solve this, please?
I'll let a print with the problem.
PS: the language of the print it's Brazilian Portuguese.
1 Reply 1
Do you mean that you cannot change the number of decimal digits in Project Preferences > Calculation Units & Rules normally?  Or that the value changed mysteriously on its own?
This is (unfortunately) not a setting that can be changed from view to view... but is a global, project preference.  This dates back to Archicad's earliest days, and there has been a wishlist item for years to allow this preference to be made view-specific.
