KenMcN
Can a Zone show both m2 and ft2?
We need to provide floor plans showing areas in both square meters and square feet, does anyone know if it is possible to customise a zone stamp to do this?
If there is a way to take the measured area in m2 and multiply it by 10.764 then display that (adding "sq ft" to the end), that would be fine, but I can't find a way to multiply an area within Archicad.
All help gratefully received,
Kenny
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
5 Replies 5
RandyC
The attatched works for property calculations - you should be able to steal the script and add it to any stamp you prefer to use.
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
vistasp
Mentor
Have a look at this zone object, Randy. You can try the demo and see if it works for you.
http://aclabels.net/
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
RandyC
Visap that one looks a bit more sophisticated than mine and would work
for the zones that KenMcN requires
Mine has the code that could be made into a stamp that would satisfy KenMcN
if he wanted to create his own. In either case the answer to the subject
is yes.
RandyC
Vistasp --- sorry I spelt your name incorrectly - pressed reply to soon.
vistasp
Mentor
No worries Randy. I too made a mistake by addressing that post to you instead of Ken.
= v i s t a s p =
bT Square Peg
