Project data & BIM
Can a Zone show both m2 and ft2?
KenMcN
We need to provide floor plans showing areas in both square meters and square feet, does anyone know if it is possible to customise a zone stamp to do this?
If there is a way to take the measured area in m2 and multiply it by 10.764 then display that (adding "sq ft" to the end), that would be fine, but I can't find a way to multiply an area within Archicad.
All help gratefully received,
Kenny
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
5 REPLIES 5
RandyC
The attatched works for property calculations - you should be able to steal the script and add it to any stamp you prefer to use.
ArchiCAD 4.5 --- 27 , Win 10 , dual monitors, 64 gb ram,Nvidia GeforceRTX 2080 TI, I-9
vistasp
Have a look at this zone object, Randy. You can try the demo and see if it works for you.
http://aclabels.net/
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
RandyC
Visap that one looks a bit more sophisticated than mine and would work
for the zones that KenMcN requires
Mine has the code that could be made into a stamp that would satisfy KenMcN
if he wanted to create his own. In either case the answer to the subject
is yes.
RandyC
Vistasp --- sorry I spelt your name incorrectly - pressed reply to soon.
vistasp
No worries Randy. I too made a mistake by addressing that post to you instead of Ken.
= v i s t a s p =
bT Square Peg
