‎2025-12-04
12:58 PM
‎2025-12-04
06:23 PM
Hi!
I want to add new surfaces. I did it multiple times, but sometimes something doesn't work and i cant do it.
I'm doing it like always - options - element attributes - surfaces - add. Im chosing png texture from my pc, but i cant see it on the preview box. There's only white area and it seems like Archicad didn't add my texture at all. It happens some time to time and i don't know what does it depend on.
Solved! Go to Solution.
‎2025-12-04 01:00 PM
Hi.
First, you have to add the texture(s) in the embedded library library (from the library manager).
After that, you have to use your image texture in the surfaces menu, as a texture for your chosen surface.
Hi.
‎2025-12-04 01:38 PM
Or if you have multiple jpegs or pngs you can add the folder of those to the library instead of the embedded library.
