Comand H (Hide) on a Mac is disabled
I loose my command H quick key for hiding the Archicad after exporting my work environment. Have other Mac users experienced this problem? Anyway to get it back? I use command H all the time, but would also like to be able to export my work environment. Thanks for any feedback.
11 Replies 11
David Maudlin
Folks:
You can also look at:
http://archicad-talk.graphisoft.com/viewtopic.php?p=23162&highlight=hide#23162
From my dim memory: If you started with a recent default keyboard shortcut scheme (ArchiCAD 8 or 9), it was not possible to assign Command H to anything (the application will hide when imputing the key combination in the Work Environment, of course). For users wanting Command H for Stretch (ArchiCAD 5 or 6), they needed to go to the Work Environment and start with an older scheme that used Command H by default. I think if you start with an older scheme, Command H is gone for Hiding ArchiCAD, and will not come back even if you remove Command H from a keyboard shortcut. I just tried exporting my own Profile, but Command H remained for hiding ArchiCAD.
Hope this helps.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks everyone. I had re-assigned stretch but had not removed the command H that is assigned by default. I had created this work environment on a PC where it wasn't an issue. Expose is great but I guess those old habits die hard and I still find myself using command H .
