Connection beetwen 2 columns
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2023-03-03
08:00 AM
‎2023-05-20
12:46 AM
Gordana Radonic
In 3D columns (same material) get connected and there is no line in between. Is there a way to remove line that breaks connection in plans? (other than creating unique complex profile for column)?
- Labels:
Attributes
Change & Issue Management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2023-03-03 08:42 AM
Not that I know of unfortunately.
The custom complex profile columns is probably the best alternative.
There is the 'Patch" tool that most people have forgotten about.
Place a marquee around the area you want and create a patch.
That will create an object that you can open the script for (CTRL+SHIFT+O) and then edit the '2D symbol' view - which is just lines and fills.
Save and you will get what you want - basically an overlay.
But for every unique column, you will still have to create a unique patch.
And they can be very confusing if you don't remember they are in place.
