2018-03-01
05:48 AM
2025-08-06
05:00 PM
Aruzhan Ilaikova
2018-03-01 06:25 AM
Riczmond wrote:That was going to be my suggestion.
I know that I can delete all settings in the source file (make it blank), but it takes a bit of time each time.
2018-03-01 02:32 PM
2018-03-03 03:04 PM
2018-03-06 03:19 AM
LaszloNagy wrote:I am not so sure that it does not contain the actual attribute as well.
You could try to save the old Project File as a Module (*.MOD) file. MOD files contain only references to attributes but not the definition of attributes themselves.
A .mod file refers only to attributes actually used by their elements. Thus, a .mod file is muchBut I have always understood this to mean that it will 'contain' only the attributes that have been used.
smaller than a .pln file
2018-03-06 09:31 AM
2018-03-10 09:57 AM
Barry wrote:Hi Barry,LaszloNagy wrote:I am not so sure that it does not contain the actual attribute as well.
In the reference guide it says this ...
I am sure it will still create these attributes if they do not exist in the file the .MOD is being added to.
