Project data & BIM
Date in change manager
Guillermo1
Can the date format be modified in the change manager? DD/MM/YYYY
 Operating system used: Mac Intel-based 14
Guru
On Windows anyway, it reflects your system settings; Short Date. I assume macOS would be the same.
Guru
Thanks! it works perfect, i change the format in System settings and restart my laptop , now looks good!
Setup info provided by author
