Deleting Single Instance of Hotlink
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2018-10-09
03:36 AM
‎2023-05-25
06:29 PM
Rubia Torres
‎2018-10-09
03:36 AM
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-10-09 03:41 AM
‎2018-10-09
03:41 AM
With groups enable (toggle: alt + g), just select any element in the instance of the hotlink you wish to delete and it will select that entire instance, even across stories, of which you can then delete. While groups are suspended, you cannot change anything with an instance of a module.
It would be nice if you could still move modules with groups suspended if you have selected all elements within the module... Quite a few times I have tried to move several things including modules and left half the things behind due to them being part of a module...
Ling.
Ling.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-10-09
03:41 AM
Ling.
Ling.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2018-10-09 04:51 AM
‎2018-10-09
04:51 AM
Thanks Ling! Did the trick!
