Project data & BIM
Dimensions on various rapresentation scales
HI,
I'am an Autocad Architecture user. In this software we have the possibility to create a linear dimension and choice at what rapresentation scale whe want to see them, and not...i'm searching a similar possibility on ArchiCAD (i'am a good user, but i don't like use layers settings)
Thank's to all and sorry for my bad english, i'am attempting to learn it better.
4 REPLIES 4
Eduardo Rolon
Dimensions in Archicad will always display at the same size independent of the drawing scale as a default. Yo do not need to set different sizes of dimensions based on the drawing like in Autocad.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
NCornia
Graphisoft Alumni
Graphisoft Alumni
Eduardo has it correct but I thought I would just add a little meat to the conversation.
Before AutoCAD 2008 you had to draw your dimensions in the model space at a height that would be visible when printed on the layout. So text would have to be drawn at i.e. 6" or 2' high in the model space, depending on the scale of the resulting output. Annotation Scaling was introduced to AutoCAD and AutoCAD Architecture in version 2008. This scaling function is equivalent to what has been in ArchiCAD for several years (I assume since the beginning but some of our veteran users would have to verify that since I can only verify back to AC7-2001.)
In ArchiCAD, when you change the scale in Model views the annotative elements (text, markers, dimensions, etc.) will enlarge or decrease with relation to the model [EDIT: inverse of what ER said but effectively the same]. When you change the scale of a Paper element such as a drawing on a layout (open the drawing settings to change the scale of a drawing) the scaling effects the annotative elements and model elements the same, essentially resizing the drawing graphically.
Here is our Help doc on the topic: file:///Applications/Graphisoft/ArchiCAD%2016/Help/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#href=01_Configuration.04.18.html
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Thank's for your responses, but my answer is: in Autocad Architecture i can make invisible one dimension at one specified rapresentation scale withouth using a new layer setting. It is possibile make a similar condition for each dimension in ArchiCAD(...only in the annotation property, not using differents layers for each rapresentation scale...)?
Eduardo Rolon
The answer to that one is no. You will need different layers for the Dimensions.
That might be a nice setting to have.
AC29 US/INT -> AC08
another Moderator
