Gisele
Door Schedule - Frontstore door
How to make a door that is part of a front store show in the door schedule?
AC 26 - 5002 USA FULL
Win11 Pro 22H2 - 13th Gen Intel(R) Core(TM) i9-13900KF 3.00 GHz - 64 GB - 64-bit operating system, x64-based processor
1 Solution
Create the Storefront using the Curtain Wall tool, and use the "Curtain Wall Panel - Door" Favorite or similar to place Doors into it.
Make sure the Doors in the Curtain Wall are classified as "Door", just as other Door elements.
Then, in the Door schedule, you should schedule elements that are found in the "Door" branch of the Archicad Classification. Actually, in the INT version, the "IES-03 Door Schedule" Schedule of the default Archicad Template does it that way. You can check out its Criteria for reference.
Go to post
Gisele
Thank you.
