Paopao
Exporting layers to other files. HOW?
Is there a way to export selected layers (and possibly merging them into one) ? I have tried the Element Attribute options but I only seems to export empty files. Am I doing something wrong or there is no way to do it?
Thanks
PP
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
4 Replies 4
David Shorter
Hi Paopao
Exactly what do want to export and to what?
Are you exporting to another ArchiCAD file or another software?
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Bruce
If you want to export layer definitions, use the attribute manager. If you want to export the content on particular layers:
1. Turn on what you want - turn off everything else
2. Use the thick marquee to select everything
3. Go to File > External Content > Save selection as module
You can then open and save as a pln, or import into another file and break the link.
To merge layers, just delete one, and you will be asked which layer to place the content onto.
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Paopao
David wrote:
Hi Paopao
I need to exchange layers between Archicad files.
Paopao
Thanks! That may be the procedure I am after! I am going to try it.
