Project data & BIM
Expression property consisting of: Layer name + "/" + Parent ID name. How to do it?
TKnudsen
I am trying to make a property with and expression, so that elements automatically looks like this:
"Layer name" + "Parent ID" divided by a "/" symbol.
For example:
"YVH-01/A" - Where 'YVH-01' is the name of the layer and 'A' is the Parent ID.
Can anyone help with an expression for this?
Thanks 🙂
Here you go:
CONCAT ( {Property:General Parameters/Layer}, "/", {Property:General Parameters/Parent ID} )
You can just copy this into the expression editor and it will recognize the parameters.
Hope that helps 🙂
Bernd
Here you go:
Hope that helps 🙂
Bernd
Thanks a bunch Bernd! 😊
