2 weeks ago - last edited 2 weeks ago by Barry Kelly
hello everyone this is the first pic.1. these are the textures that i want to delete from my archicad list i don't want them i want my archicad clean.
This is the second pic.2. I've tried to delete from here but it's no use, when i open Archicad again they aren't delete.
Anyone know this problem can someone help me please !!!
Thank you.
Solved! Go to Solution.
2 weeks ago
Some library object may be bringing them in. I would take a look in the library manager to find the culprit.
I had a similar issue with an AC13 mastergdl file that was importing a ton of textures from an object pack and attribute manager only fixed it temporarily.
2 weeks ago
You have to delete these through the Attribute manager or Attribute Palette.
But be careful that these surfaces are not used by your objects and building materials.
These look like standard surfaces that are used by the default Graphisoft objects and building materials to me, so you may not want to delete them.
Just ignore them or maybe move them into a folder called 'obsolete' (or what ever you want to call it) - this can be done in the Attribute Manager..
2 weeks ago
I tried to delete them in fact i delete them but when i open my file again i still have those textures that i don't want them. If you have any other idea how can i delete them ? thank you
Berat.
2 weeks ago
2 weeks ago
hmm okay i understand but you know what's interesting it's that when i open another file that i dont have that (object) still it will appear these textures.
But i will try to what you said and i hope i will have success.
Thank you so much
2 weeks ago
I am pretty sure something in the embedded library is carrying the textures - i recognised the name hellandconfort and I clearly remember struggling to also get rid of them.
2 weeks ago
yes yes i found it thank you sooo much man 😄
