Project data & BIM
Hotfix 1086 -Have you installed it?
Hi folks,
Has anyone installed hotfix 1086?
Did it fix what they said it did?
Any problems to report?
thanks.
7 REPLIES 7
Thomas Holm
Nathan wrote:
Hi folks,
Hi!
Yes.
Not sure.
None at all specific to this hotfix.
thanks.
You're welcome!
Now i've installed it, and here's what i've found.
Somethings work, my files with hotlinked modules are 5% smaller.
Stupid markers that showed on elevation in layout only are gone.
And I couldn't get a linked marker to loose its link.
BUT
When I tried cutting the above linked marker from one elevation, and pasted it to another, AC crashed.
Don't tell me you can't cut/copy paste markers around the model...
"You cannot paste data into a section window with hotfix 1086 installed."
I have just read this at this link:
http://archicad-talk.graphisoft.com/viewtopic.php?p=103440#103440
Perhaps it's also related to your problem of cutting and pasting the actual marker. Same result anyway
Edit: Ah yes - you're pasting in elevation... that's it!
I asked you not to tell me that.
But thankyou.
When I searched the forum for "1086", why didn't I see any post that said something like
DO NOT INSTALL HOTFIX 1086 FOR FEAR OF DEATH!!!!
Hmm. Should I uninstall and reinstall to get rid of the hotfix?
You can't paste into Sections/ elevations? Is Quality Assurance/ Control unheard of at GS? What good is this hotfix?
PS I like the wink.
Sorry
They give instructions in that link I posted above. I suppose best to follow those... That linked post was up only about half an hour before your own post - that's why you couldn't find it in your search I'd imagine.
PS I like the wink.
Thank you 😉
Thomas Holm
That's been mentioned before. Do a search! I don't think it's specific to hotfix 1086, at least I had the problem occasionally before that hotfix. Since cut and paste in sections only gives you 2D I tend to minimize that anyway. I would like to have full 3D editing in sections as well as in the 3D window though. Hoping for AC12...
Greg Kmethy
As far as I know, the crash occurs if you copy/paste elements into a section that has markers in it that directly refer to drawings placed on layouts.
This bug has been recently identified, and very soon (in a few days) we are going to issue a Hotfix that corrects it.
I believe if you hide the markers, the crash will not occur.
Sorry for the trouble it's causing you.
Gergely Kmethy
