‎2007-12-18
02:32 PM
‎2023-05-26
09:03 AM
Rubia Torres
‎2007-12-18 05:08 PM
‎2007-12-18 10:27 PM
Melisa wrote:I believe that being on the same layer is not a criteria for Wall clean up.
Are the walls in the hotlink on the same layer name as the host file? If they are, they should clean up.
If they are not, then make sure that the index number for the layer is the same for the hotlinked walls as for the native walls. Do this in the host file. And it needs to be done for each layer combination.
Hope it works!
Melisa
