Project data & BIM
Hotlink module does not appear?
Hi everybody,
I hotlink a file into the host file (16 storeys). This hotlink is placed on floor 16th. But it does not appear after I finish the hotlink dialogs. The screen is black as like nothing there. I looked in perspective window also but nothing happed.
Does any body know any reason?
Please advise
p.s.: I'm using AC 12 right now...my signature is obsolete temporarily.
hi,
In addition to my previous post, I also hotlink other typical floor into the same host file. They are all fine. Appeared properly in plans, elevations, perspective....
So I don't know what went wrong with floor 16 per my previous post.
Please advise.
Many thanks
If you open the source file of the Hotlink, is it OK? Does it have the elements in it?
Does the Hotlinked Module now appears among the list of files in the Hotlink Manager Dialog?
Is it possible that the Master Layer of that Hotlinked Module got hidden somehow?
hi,
The modules itself is fine when I open.
All the layers are on, even the master layer.
Still I don't know the issue...really weird !
Other modules in the same host file work well except this module...
Should I send you the file to have a look?
Please advise.
Thanks and Cheers
