2008-10-22
		08:38 PM
		2023-05-26
		09:02 AM
			Rubia Torres
2008-10-23 01:54 AM
2008-10-23 03:46 AM
2008-10-23 03:51 AM
2008-10-23 07:47 AM
2008-10-23 07:55 AM
Erika wrote:I tend to use SEO to fix this situation. Have you tried that?
To resolve this, think it through how it will be built. In the real world, a wall and a column will not occupy the same space, although they can in the virtual world....
2008-10-23 08:27 AM
Thomas wrote:I've never seen an SEO machines at a job site. Do they have them in Sweden?
2008-10-23 09:42 AM
2008-10-23 03:51 PM
rucailo wrote:Don't you have insulation or plaster or something on the exterior side of Walls?
I went over the floor plan and deleted the columns and the problem was fixed.
It looks like I will have to place the columns in the source floor plan of the hotlink module, but that is not what I want because as I said before, the columns are going to change dimensions every 3 stories and then my hotlink modules are going to be a mess, is there a way to place the columns over the modules and correct this problem?
I will send 2 pictures, one with the column and the other turning the column layer off and you will see how the column shows in the floor plan and in the elevation I previously attached,
Thank you for helping me.
2008-10-23 09:16 PM
