How to remove "story" info from a favorite.
I've found that when I create a favorite, for example object or wall, it keeps story info. So if I try to insert that element in a different story, ArchiCAD gives me a message saying
"As a result of the last operation element has been created and/or have changed their position on currently unseen stories".
I know I can change that setting before inserting, but it kind of defeats (partially) the purpose of using favorites. Is there a way to remove "story" info from a favorite so it works relative the story you are in?
I've noticed sometimes it doesn't apply story, but I can't quite find out why/when.
Thanks.
14 Replies 14
In version 22 go into the favourite settings and choose "Element transfer settings".
There you can choose what info to use with each transfer setting.
In earlier versions I think it is just call 'Favourite Preferences' or something like that as they don't have the option for multiple transfer settings.
See this clip for details:
...Home Story is unchecked and favorite still adds wall on another story, ...am I missing something?
...I think it works. I just needed to change the "Home" once and now it is "live". Is that what I was missing?
Possibly.
It never used to work at all in older versions but it was also done a little differently then.
Maybe it just needed a little nudge.
Thanks Barry!
Thanks Laszlo!
TaniavH
Hi all,
I'm having the same trouble and it's very frustrating - I have changed the Element Transfer Settings multiple times, created several new ones and applied them, but it still attempts to apply a default home story (the one which the favorites were created on) to walls (it seems to have rectified itself for Zones though)....what am I missing?
(using ArchiCAD 22)...
Thanks!
TaniavH
restarting ArchiCAD seems to work....sigh.
