Llian
How to set to all as New Construction
This Renovation-Existing is driving me crazy...I am spending so much time in changing my objects to new. How do I set the project as New Construction? My drawing layer combination is New construction...
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
13 Replies 13
Layer combinations don't have any correlation to Renovation filters.
I would do what you need by permanently enabling Renovation Palette (Window > Palettes > Renovation )
And setting "New" as a default for new elements by clicking on the "New" icon.
Note: "New" icon will be greyed out if the current renovation filter is set to hide new construction elements.
Llian
Thanks Anton....this is so helpful.
You can change the Renovation Status of all elements in a single step:
1. Go to 3D Window and show all Layers.
2. Select All.
3. Use the Edit Selection Set command (CTRL+SHIFT+T on Windows).
4. Change "Renovation Status" field to desired value and click OK. It will be modified for all selected elements.
BTW, why is not Archicad set up by default to make all elements new? I think is more common than existing, probably.
You are raising a valid point.
Maybe it is because there can be two cases:
1. There won't be renovation-related things going on in the project file. In this case the Renovation Status does not really matter.
2. There will be renovation-related things in the file. In that case it is best to set things to "Existing" since that is the first stage. Then things can be selected and changed to "To be Demolished" as needed. If the reno status of elements were set to "New" by default, they would all have to be changed to "Existing" in case of Renovation projects. Maybe this is why they chose "Existing" to be the default Renovation Status.
Yeah, Probably. make sense.
I really never had to use them yet as they are meant to be used, until now I just have use them as a design options tool
I Just read this post and became curious about it.
Have a good weekend.
Erwin Edel
I prefer the existing as default option.
Even with completely new projects I sometimes end up going into a demolish and new status for elements, either by revisiting it later for a new extension, or by having to 'hide' something from permit documentation and needing it for building documentation again later.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
David Shorter
In Australia our default template is set to NEW, this is because most of what we build is NEW.
You can reset all the renovation settings using the Reset Renovation Status option as shown
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
MDunkin
How do you create something without a renovation status?  For example a zone.
AC28: Win10 Pro, 12th Gen Intel(R) Core(TM) i9-12900K 128gb ram, RTX-A6000
