Importing element parameters
Hello, I would like to know how to importe layers and layouts from one template to an other. The idea is to merge elements parameters useful for project estimation from one template to an other template.
Tank you for your help
Lingwisyer
Guru
Layers can be done via the .
Layouts can only be copy / pasted between files as far as I know.
Ling.
James B
To transfer Layouts.
Open both files (Project A and Project B).
In the one you want to add the Layouts to (Project B), open the Organiser.
On the left, open the top left popup to switch to view your other project (Project A).
Switch to the Layouts view on both side - Layouts of Project A on left, Layouts of Project B on right.
Drag and drop layouts from Left to Right.
(make sure both projects are saved)
All Layouts moved across, will be linking to views from Project A.
And here's the link to the Attribute Manager help page for Archicad 24 (above links to AC22, as there have been some changes over the last few versions):
https://helpcenter.graphisoft.com/user-guide/127896/
James Badcock
