2005-02-22 06:47 PM - last edited on 2023-05-26 03:56 PM by Rubia Torres
2005-02-22 07:17 PM
eugenic wrote:
When I import a view to a layout in Plotmaker, it's imported not in the same scale as it is defined in ArchiCAD.
2005-02-22 08:49 PM
2005-02-22 09:29 PM
2005-02-22 11:00 PM
eugenic wrote:
I've checked many times. The scale in View Set is set to 1/8" but when I try to import it in Plotmaker, it's still recognised as 1/4". I wonder if that's a glitch in 9.0.1 update.
2005-02-23 02:24 AM
woodster wrote:or you have over-ridden your drawing scale settings in plotmaker manually - either in the global preferences, or by specific drawing (right click on imported drawing>Drawing Settings...>Attribute Update Rules(?) )
Either the View is not set in ArchiCAD at the scale you desire or you are not importing the view you think you are.
2005-02-23 04:24 PM
