2023-03-22
03:54 PM
2023-11-15
10:39 AM
Aruzhan Hamar
I just got the Archicad Educational Version, which somehow defaulted to english eventhough it should have been in german. Furthermore the dimensions are very confusing, for example, i have to put in 3000 Meters to get 3 Meters, when i open a new File the Floor and Story settings also automatically show 3000 (I guess meters) but if i select a dimension line it shows 3,000 meters so that works fine, it´s just incredibly annoying to have to write out 12300 to get a lenght of 12,3 Meters
2023-03-22 03:56 PM
Look up your "working units" (Arbeitseinheiten). They are currently in millimeter for you.
2023-03-22 04:29 PM
Regarding INT (English), that is probably what you downloaded. Not sure about the educational version (my school days are long behind me!), but the 'regular' download page has a not-so-obvious button that enables a pull down menu with all version. It defaults to 'INT'.
2023-03-22 04:29 PM
2023-03-22 05:04 PM
If it's the educational version it should be downloaded from myarchicad.com anyway. Then there will be no other version to download then the right language version.
2023-03-23 09:20 AM
Yes, I knew this was not the place for the EDU download, but I sort assumed GS would've done the same overhaul on that page.
In the past I would get a direct link to the NED version too, but recently I end up on this page and it defaults to INT and then I have to select NED from that not-so-obvious button.
