2005-05-24
07:34 PM
2023-05-30
01:04 PM
Rubia Torres
2005-05-29 10:45 PM
2005-07-18 12:56 PM
2005-07-18 04:41 PM
Iain wrote:Attribute Manager.
the ability to "purge empty layers" in one go, rather than one by one.
2005-07-18 06:02 PM
2005-07-18 07:08 PM
Iain wrote:There is a 'Check Duplicates' (Contrôlez Les Doubles? Dashboard translation, hope it isn't rude
Now I wonder if there is a "remove duplicate objects" button somewhere,
2005-07-18 07:22 PM
Or is the only way to define "Presentation Floorplans 2" and then later go back and delete the original "Presentation Floorplan" combination?You can actually do it all at the same time if you want to do it quickly. This is the best method IMHO - only takes a couple of seconds. Either way, viewsets remember the layer combination assigned to them by name, not ID, so it doesn't really matter when you do it, as long as the new name is identical to the old one.
Attribute Manager.It's worth noting that purging layers in the Attribute Manager does not necessarily delete
2005-07-18 10:13 PM
Link wrote:Tip: Before purging, use the Active Layer palette switch to set all the tools to the ArchiCAD layer.
It's worth noting that purging layers in the Attribute Manager does not necessarily deleteallempty layers. Purging layers this way will delete all empty layers (layers with no content in them in the drawing area, including floor plans, S/E's 3D window, Detail windows), *but* it will keepall default tool layers
2005-07-18 10:47 PM
Tip: Before purging, use the Active Layer palette switch to set all the tools to the ArchiCAD layer.Touche James!!
2005-07-19 01:47 PM
Link wrote:Sounds like you use it about as much as I do. I use it to, well, purge layers. That's about it. I don't have many occasions to want everything on one layer. I could imagine using it to develop schematic alternates, where everything is either on the Option1 layer or the Option2 layer; never done it in practice though.
it shows how much I use the Active Layer!
2005-07-19 02:14 PM
