2008-05-16 12:31 PM - last edited on 2023-05-30 12:53 PM by Rubia Torres
2008-05-16 02:11 PM
2008-05-16 02:27 PM
2008-05-16 02:58 PM
David wrote:Thanks for that, David. I can see where you're coming from, but wonder whether in our case standardisation might get in the way. Suppose you had several views all using the 'Structural' layer combination, then you modify 'Structural' by switching a layer off, only to discover that in some of the views, you'd lost a layer that you really needed to keep. So you add a new layer combination called 'Structural +' . Then at a later date you modify that combination and you've got to check all the views which use that combination to make sure that you haven't messed them up too.
If you have a Layer Combination named "Structural" and need to modify your Structural drawings, you need only modify the Layer Combination
2008-05-17 10:02 AM
2008-05-17 03:11 PM
Keith wrote:Keith:
