2007-08-12
09:48 PM
2023-05-30
12:56 PM
Rubia Torres
2007-08-13 07:01 AM
2007-08-13 07:31 AM
Link wrote:there isn't a magical default . . . but there is the 'Intersection in Layer Combinations' add-on which sets 1's and 2's based on current visibility.
Trust me Steve, there is no magical default.
2007-08-13 08:39 AM
2007-08-13 02:37 PM
2007-08-13 05:12 PM
Steve wrote:I think you've answered you're own question right here. If you want to navigate through your project w/o affecting the current model view and layer settings, use the project map. Switching views from there will allow you to adjust elements from multiple views w/o readjusting your layers every time you switch.
What If I don't want to change views by using the view maps?
Perhaps I am using the project maps instead.
2007-08-13 05:13 PM
2007-08-13 07:41 PM
2007-08-14 12:00 AM
Steve wrote:you answered your own question again before you asked it:
You can get what you want by other means, leaving all of the group numbers set to 1. Why use it?
2007-08-14 12:12 AM
2007-08-14 12:23 AM
