Project data & BIM
Layer Purge
Mcneel Rhino has this simple, yet effective tool where you can type 'Purge' and it optimizes my Layers. Basically it get's rid of every Layer that is not being used. This would be helpful. Thank you.
Eduardo Rolon
It has been hiding in Attribute Manager since forever
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
Wow. I wish I asked this years ago. Thank you!
