Project data & BIM
Layer Settings in Favorites not working in Archicad 23
Fairly new to Archicad as far as moving a template to a new Archicad version. Just upgraded to Archicad 23 from 22. Imported Archicad 22 favorites into Archicad 23. When I select a particular Favorite and right click to Edit, the Layer is listed correctly. When I double click the Favorite to insert in drawing, it seems to use the previous Layer (which is also the layer listed in the Info Box). Seems to happen with all Favorites (walls, objects, etc). Tried exporting same favorites from 23 and re-importing - did no good. Am I missing an upgrade/import step somewhere? All else seems to work ok. Any assistance is appreciated. Thanks!
1 REPLY 1
Found my answer... Element Transfer Settings. "Exclude id/ layer" in transfer was selected.
Thks
