2004-05-21
03:01 AM
2025-01-30
12:51 PM
Molinda Prey
2004-05-21 04:08 AM
Steve wrote:Let me see if I can help with my first post to Archictalk.
I have a 8.1 ArchiCad Project ..... the layer combo does not take effect.
2004-05-21 09:35 AM
Steve wrote:Steve,
I have a 8.1 ArchiCad Project that is a floorplan with several layer combinations. I want to import this project to two different layouts in a layout book. I want to use one layer combination on one layout to print certain layers, and another layer combination on the other layout to print other layers, but not the first. I have the layers I want to view in each layout set up as layer combinations, however in Plotmaker if I select the combinatin I want to view the OK button is not active so I cannot change the layer combinations. Why is this? The User Guide says I should be able to turn layers on and off (show and hide) in Plotmaker, but the OK button is never active unless I select All Layers, but yet when I do and select my layer combo, nothing changes, the layer combo does not take effect.
2004-05-21 08:01 PM
2004-05-21 08:03 PM
2004-05-21 09:09 PM
another Moderator
2004-05-22 08:57 PM
Steve wrote:Welcome, Steve.
I will assume you are talking about publishing when you say to save the VIEW.
