2017-11-14
09:51 AM
2023-05-30
12:37 PM
Rubia Torres
2023-02-10 06:39 AM
Problem is still there in AC25.
Actually worse.
I set the desired Layer combo in the Quick Options Bar.
It flicks the name up for a split second, then turns to "Custom"
I publish a set of layouts with this cutsom layer combo setting.
half the drawings are OK, the other half has the title block layers turned off!!!!!!!!!!
GS pls fix this problem ASAP!
2023-02-15 09:21 PM
I am having the same issue. It appears to have happened after importing layer combinations with the attribute manager.
2023-02-16 01:03 AM
I doubt it has anything to do with importing layer combos. I never did that, yet the problem is there.
2023-06-01 03:36 AM
Same problem occurred for me after importing layer combinations from another file.
It seems the layers combinations got a bit confused and every possible change reverted to "Custom".
The fix for me ...
I created "New" combinations based on each existing one and appended "2" to the name. Then deleted the old ones and finally renamed the new combinations without the "2". Need to then reassign the layer combinations to each view.
AC26 MAC
2024-01-25 02:11 PM - edited 2024-01-25 02:29 PM
Same on AC-27. After deleting a bunch of unwanted layers, after import of layer combinations.
Updating won't solve the issue.
1) Yes , in the layer combination are references to deleted layers. But hey, importing layer combinations is a a common workflow, and deleting unwanted layers also. So..
2) Yes this is an official bug.
3) Since how many years already ?
4) Workaround is time consuming. 🙁.
2024-05-02 09:59 AM
This is how, I have solved it:
Thanks,
Shrutiniwas Sharma
2024-06-28 12:39 AM
can confirm Open & Repair worked.
3 weeks ago
Problem persist in Archicad 28 as well and is really annoying. Graphisoft didn't came with any solution?
AC26 3001 UKI (from AC13)
HP ZBook Power 15.6" i7-13700H @ 2.4Ghz, 32GB RAM, NVIDIA RTX 2000 Ada Gen, 1TB SSD, Windows 11 Pro
MacBook Pro M1 Max 14.2", 10-core CPU, 64GB RAM, 32-core GPU, 1TB SSD, MacOS Ventura 13.6.2
Self-guided, shape it until it shifts.
