β2011-03-01 03:37 PM
β2011-03-03 07:53 AM
β2011-03-03 09:45 PM
β2011-03-03 11:00 PM
β2011-03-04 04:51 AM
s2art wrote:Hi Stuart,
As you can see on the attached image, I have layers with EXTG or DEMO extensions, which, for new build work are not needed. These are preceded with a Z in their name to send them to the bottom of the layer list. If the job requires them, just delete the Z- from the beginning and they move to the appropriate order in the layer list, and co-ordinate with existing / proposed views. Does this seem feasible? Changing layer names is o.k. but changing layer combination names makes them "missing" in saved views (at least in AC11).
Feedback welcome.
β2011-03-06 09:11 PM
Link wrote:Not seen as criticism, all good advice (which is why I asked the question).
Hey Stuart
I'm not criticizing your method at all, just shedding light on various methods.![]()
I doub there's a right or wrong answer, and like pensets, they work best when they work for you. It is good to hear and see different approaches though. Do you often sort by extension?
Link.
β2011-03-06 10:32 PM
β2011-03-06 10:54 PM
Link wrote:Yeah, that was the point I was trying to make to Barry, not very clearly.
Hey Stuart
Just keep in mind that you can only sort and filter by extension in the Layer Settings dialog box, nowhere else. Hence my initial comment about extensions not being a replacement for good layer naming conventions.
Link.
β2011-07-17 02:57 AM
β2011-08-18 04:56 PM
β2011-08-18 05:08 PM
