Our customers might be experiencing service disruptions due to a global outage at Microsoft Azure. Our team is actively monitoring the situation and working to minimize the impact. Thank you for your patience and understanding.
Project data & BIM
Layer extension
Hi everyone,
I know it may sound like a silly question, but what is the goal of the layer "extension"?
25 REPLIES 25
vfrontiers
Just a guess... but if someone typed in a "." it will change to an extension. Maybe they were not realizing they were "extending" layer names?
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
In my experience - yes.
We used to have "." in our layer names when we first started (V6.5).
Somewhere along the way (might have been 8.1) the part of the layer name after the "." became the layer extension.
We ended up renaming them all to avoid the problem.
Erika Epstein
Barry, the '.' serving to define what comes after it as the extension has been present since at least 5.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
We have only been using since 6.5 but I don't have it installed any more.
But we definitely had layers with "." in them and no layer extensions.
One was "Furn. & Equip. (2D & 3D)" and another "Gable ends and ext. det."
It wasn't until 7 or 8.1 (can't remember) that these automatically became extensions.
But now the "." is definitely an extension separator.
You can have more "." in the extension but I don't think I would want to try this.
The "." has always been the extension separator (since named layers were introduced with v4.0). It appears from your experience that there was an exception when the dot was followed by a space character but that this is no longer the case.
Maybe it is only southern hemisphere versions, but I have the same recollection as Barry - we used to have layers called "Services: d.p.s" (for rainwater downpipes) which in a certain version (not sure which) changed to having an extension.
