Takis
Layer settings and Layer Combinations
Hi, in Archicad 20 INT Build 5025 I have a problem while in section and Elevation views.
While a section or Elevation view is open (double click) then press Layer Settings button.
The active Layer Combination is not selected. Instead the very first Layer combination is selected.
This is happening only with section and elevation views.
This is not a 5025 build problem, it is from the very first version of Archicad 20.
Could you please check it out.
Thanks.
0 Replies 0
