2007-09-06 03:57 PM
2007-09-06 05:01 PM
2007-09-06 05:37 PM
Link wrote:I guess this is my concern as well- because I AM loading the library folder as a whole, and archi cad is seperating the parts out into the Other Objects, while also leaving my Project Library folder loaded under Libraries......
What's more of a concern is that your objects are coming in under the blue 'Other Objects' folder. You should be loading the whole library folder, that contains all other subfolders (if any) and the library parts contained therein.
Link.
2007-09-06 06:06 PM
2007-09-09 02:09 PM
2007-09-10 01:50 AM
Jesikuh123 wrote:Not quite sure if this relates... but ArchiCAD will automatically load newly created objects as 'other objects' so they are available for use without having to reloaded all libraries. If the objects are being saved into the project library as they should be then you can simply clean out all 'other objects' occasionally.
