‎2025-04-14
07:02 PM
- last edited
4 weeks ago
Hi.
Im having trouble managing fill scales. I have a composite with a skin that is a "water membrane". The drawing at 1:50 looks fine. When i try to draw that same fill independently, the fill comes out:
1. not at the same scale as it shows in the composite wall (even though is it set to "scale with model")
2. what was supposed to be white is appearing as reddish now;
Any ideas?
Z
‎2025-04-14 11:49 PM
Did you try to draw it as a line and not as a fill?
Generally when i'm drawing a detail at scale 1:20 or 1:5, I use different line for it. In your template You should have some line with this geometry
Greetings
Matteo.
‎2025-04-15 01:00 PM
Hey man. I was trying to keep the same fill pattern as much as possible. I will try the lines as well, but i am intrigued to why this happens.
Z
2 weeks ago
You were right, Thank you so much for the suggestion.
2 weeks ago
You're welcome 🙂
2 weeks ago
a week ago
Hi Diseno14,
It is selected as building Material (Cut Fill), yes.
Its a scale problem.
a week ago
Hi!
Could you send a screenshot of the fill definitions?
